MySQL Query error - Divide By Zero workaround?
Thread begun 4/24/2009 8:02 am by tom92909 | Last modified 6/29/2009 9:13 am by Ray Borduin | 17228 views | 8 replies |
tom92909Beta Tester
I didn't really know where to place this new thread. It's data related, so I picked DataAssist.
Anyway, I have a query for MySQL that I am trying to obtain a percentage change from one years total sales to another years total sales on each item record. Some of the records have zeros in the calculation fields, which causes a huge problem by crashing the query with a Divide by Zero error.
Query Example:
SELECT *,
SUM( `Janunits` + `Febunits` + `Marunits` + `Aprunits` + `Mayunits` + `Jununits` + `Julunits` + `Augunits` + `Sepunits` + `Octunits` + `Novunits` + `Decunits` ) AS TotalUnits,
SUM ( `TotalUnits` - `inventory.Year1qty` ) / `TotalUnits` AS Percent
FROM `inventory`
WHERE `Dept` = 'WIDGETS'
GROUP BY Item
Is there a work around for this that I just haven't figured out? I assume this is a common MySQL issue with many more folks than just myself...
SELECT *,
IF(`TotalUnits`=0,0,SUM ( `TotalUnits` - `inventory.Year1qty` ) / `TotalUnits`) AS Percent
FROM `inventory`
GROUP BY Item
tom92909Beta Tester
Error Message...
MySQL said: Documentation
#1054 - Unknown column 'TotalUnits' in 'field list'
SELECT * ,
IF( `TotalUnits` =0, 0, SUM( `TotalUnits` - `inventory.Year1qty` ) / `TotalUnits` ) AS Percent
FROM `inventory`
WHERE `Dept` = 'WIDGET'
GROUP BY Item
ORDER BY Brand ASC
SELECT * ,
IF( SUM( `Janunits` + `Febunits` + `Marunits` + `Aprunits` + `Mayunits` + `Jununits` + `Julunits` + `Augunits` + `Sepunits` + `Octunits` + `Novunits` + `Decunits` ) =0, 0, SUM( SUM( `Janunits` + `Febunits` + `Marunits` + `Aprunits` + `Mayunits` + `Jununits` + `Julunits` + `Augunits` + `Sepunits` + `Octunits` + `Novunits` + `Decunits` ) - `inventory.Year1qty` ) / SUM( `Janunits` + `Febunits` + `Marunits` + `Aprunits` + `Mayunits` + `Jununits` + `Julunits` + `Augunits` + `Sepunits` + `Octunits` + `Novunits` + `Decunits` ) ) AS Percent
FROM `inventory`
GROUP BY Item
ORDER BY Brand ASC
tom92909Beta Tester
Error Message...
#1111 - Invalid use of group function
tom92909Beta Tester
What about something like this....
SELECT * , SUM( `Janunits` + `Febunits` + `Marunits` + `Aprunits` + `Mayunits` + `Jununits` + `Julunits` + `Augunits` + `Sepunits` + `Octunits` + `Novunits` + `Decunits` ) AS TotalUnits, (
ISNULL( (
) - `Year1qty` ) / NULLIF( `Year1qty` , 0 )
With the above, I'm getting the query to pass, but I'm getting 1's for good data only and zeros for the records that had denominators as zero (which is fine), but the records that can be calculated I need the accurate calculation to show up, not just a one.
Any suggestions?
SELECT *,
SUM ( `TotalUnits` - `inventory.Year1qty` ) / `inventory.Year1qty` AS Percent
FROM `inventory`
GROUP BY Item
didn't you want to use `inventory.Year1qty` anyway for percent? It appears you wouldn't ever have devide by zero at that point.
Another observation... the last error you got was an error in the GROUP BY.
Does the query:
SELECT *,
SUM ( `TotalUnits` - `inventory.Year1qty` ) AS PercentTop, `TotalUnits` AS PercentDivide
FROM `inventory`
GROUP BY Item
return what you expect?
tom92909Beta Tester
I took about 2 months off on this problem, and now I'm back to try and find a solution for a work around for "divide by zero" errors. I have the following that I'm working on (same as before mostly)...
SUM( Janunits + Febunits + Marunits + Aprunits + Mayunits + Jununits + Julunits + Augunits + Sepunits + Octunits + Novunits + Decunits ) AS CurrentTotal
It is possible that some of the records might have ZERO across all of the above fields.
Then I need to subtract the difference of the CurrentTotal from the PreviousTotal (previous total from the year before).
CurrentTotal - PreviousTotal = Difference
Once I have the difference amount, I then need to take that amount and divide it by the CurrentTotal and then multiply that result by 100
(Difference / CurrentTotal)*100 = PercentageDifference
Ok, so in the example above, there are a few of the rows that appear not to have had any activity over the past year. Resulting in a fatal Divide By Zero error message. Due to accounting restrictions, I can not filter out these rows, they must remain in the result set. I'm hoping for a solution to bypass the fatal error.
Any suggestions?
Maybe try using something like:
SUM( Janunits + Febunits + Marunits + Aprunits + Mayunits + Jununits + Julunits + Augunits + Sepunits + Octunits + Novunits + Decunits ) + 0.000000001 AS CurrentTotal
and
Round((Difference / (CurrentTotal - 0.000000001))*100,2) = PercentageDifference
By adding an insignificant number to the result you can prevent ever dividing by zero without throwing off your calculation by more than would be significant after dividing.
