Blank grey activation screen
Thread begun 11/10/2009 8:09 am by info92729 | Last modified 11/13/2009 10:42 am by Dani Chankhour | 6676 views | 9 replies |
info92729
I've upgraded Site Iport from 2.0.5 to 2.1.2, but I can't get past the Activation screen. It loaded ok into Extension manager, and shows OK in thge file menu, but when I click the start button it just shows a blank Activation window.
Thanks for any help!
Andrew
Dani Chankhour
I recommend that you delete your configuration folder and reinstall your extension.
This link explain the steps:
146/
info92729
Is it possible to download the 2.0.5 that was working OK before?
Dani Chankhour
Yes. You could always go back to 2.0.5 but it always recommended to have the latest version installed.
have you tried deleting your configuration folder.
info92729
No, not yet, as don't want to lose other extensions right now. Where can I re-download v2.0.5? It's not in my downloads list in my account, only the new version ...
Dani Chankhour
Please follow the link to download SiteImport 2.0.5 at
WA_SiteImport205.mxp.zip
Let me know once it is downloaded so i can remove it.
info92729
Thanks for that, v205 now downloaded and installed. This version works OK, is that still in keeping with your advice to empty the configuration folder, or some other problem?
Dani Chankhour
If Version 2.0.5 is working correctly you don't have to delete your configuration folder. But deleting your configuration folder usually clears any corruptions that could happen from installing and uninstalling.
info92729
OK, but to upgrade Site Import you think I would need to go down the empty configuration route?
Dani Chankhour
Usually that is not case, but sometimes with a lot of extensions installed, your configuration folder could get corrupted and it is recommended to clear your configuration folder if you are having issue when upgrading to a new version.
