Lost personal sculptor files
Thread begun 3/05/2009 8:44 am by mark.hay302689 | Last modified 3/05/2009 10:11 am by Ray Borduin | 4295 views | 3 replies |
mark.hay302689
Hope someone can help - Using Sculptor I created two layouts which i use for a number of site I work on - due to a blunder I had to reinstall DW and Ext Man - As a result Sculptor no longer has these layouts on the list.. Does anyone know where they are kept.. or did they go when I uninstalled DW ?? - I've trawled my machine looking for them.
[EDIT]
Ignore this on reading further looks like iv'e lost them - Note to self.. remember to backup!!!
They should not be deleted. How did you uninstall? Hopefully you didnt' delete your configuration folder.
When you uninstall it should only remove the files that were installed, and new layouts are stored in new files and folders so they should not be lost.
The exception is if you saved over the existing layouts, in which case they may be lost.
mark.hay302689
Ray
thanks for taking the time to reply ... I simply did a standard uninstall of DW (via vista, my computer / uninstall) inc ext man then I did a standard reinstall - I can't find the files in the user / appdata / roaming folder where I thought they might be I've gone down to the config folder. I'm pretty sure the folder didn't get removed in the uninstall as I have other configs which are functional.. I've taken this opportunity to rethink my layouts anyway so 'every cloud' etc.. I'll just make sure this time i'll export them :-)
I believe they should be stored in: Configuration\Shared\WebAssist\CSSSculptor\presets
If you don't want to export every preset, you could probably just back up that folder.
