SecurityAssist js error
Thread begun 11/04/2009 10:06 am by chris373619 | Last modified 11/05/2009 2:19 pm by Eric Mittman | 2616 views | 3 replies |
chris373619
I got the same issue at the end of the installation process while using the wizard.
My error is "JavaScript error while loading WA Set Cookie:htm: at line 746 of file"macintosh HD:Applications:Adobe Dreamweaver CS3:Configuration:Shared:Controls:Scripts:WATrigger.js": ReferenceError: WA_getDocumentDOM is not defined.
I moved this post to a new thread because it looks like the specific error you are getting is not exactly the same as the other error reported in the thread. Have you tried any of the standard troubleshooting techniques like clearing the cache file or renaming the configuration folder? If not please give these things a try to see if they help to resolve the problem. Here is a link to a page that discusses the steps needed for both of these. You should try deleting the cache file first, then if that does not work for you try renaming or deleting the configuration folder.
146/
chris373619
Fixed!
I think these suggestions worked. Also, I don't think I ever opened the Cookie Plugin. When I reset everything and updated all the plugins I also made sure to open every plugin and entered the serial number.
I'm glad to hear that, let us know if there are any further issues.
