Unable to find file WA_SiteImport on startup
Thread begun 3/05/2009 4:14 am by cgarber101175 | Last modified 10/12/2009 10:14 am by t297098 | 6066 views | 4 replies |
cgarber101175
I am just about giving up on webassist products. When I tried to install the components on my new laptop with dwcs4, vista 64 bit , javascript errors all over the place. I removed all the webassist extensions and now am again stuck with the "Unable to find file WA_SiteImport " error every time i start DWcs4. How do I get rid of this error?
That error should only occur the first time after uninstalling.
If you continue to have problems, please post a support incident. It is possible you have a corrupted installation folder and you may have to manually remove some files to force a refresh.
We will help you through this process through our incident system.
Danilo Celic
Originally Said By: cgarber101175
This is a bug that I have reported to Adobe. It doesn't happen all the time, but it happens on occasion when uninstalling extensions that have a floating panel.
To fix this issue, go to the upper right corner of the application to the "workspace" drop menu, which should be to the left of the search field. If you click the down arrow, and select Reset "Designer" (or whatever workspace you're working with. Then restart Dreamweaver to see if that has corrected the issue.
If that hasn't fixed the issue, please post back.
jeff.logan376068
A similar error occured for me, in connection with the floating panel... luckily I found this post and it worked.
Thx
t297098
Worked for me 2
Had the same issue, but this solution worked for me 2.
