Dynamic, Multiple Coupons
Thread begun 4/20/2009 2:08 pm by psychobilly1165508 | Last modified 4/20/2009 3:03 pm by psychobilly1165508 | 2747 views | 3 replies |
psychobilly1165508
My client would like to have multiple coupon codes running at the same time that they control themselves. I've already set-up the database side of this and tried to follow instructions from a post in the archives from Mark Haynes here.
forumdetail.php?MessageID=%3C45a89c55%242976562c%242320c%40www.webassist.com%3A8119%3E
I get this error
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING
in /xxxx/xxx/xxx/WA_eCart/xxxxcart_PHP.php on line 100
Here's line 98 - 104:
function WAEC_xxxxcart_PromotionDiscount() {
$totalDiscount = 0;
if (true && ((sizeof($this->Items) > 0) && ((isset($_SESSION['PromoCode'])?$_SESSION['PromoCode']:"") == "$_SESSION['PromoDiscount']"))) {
$totalDiscount += ($this->TotalColumn("TotalPrice") * $_SESSION['PromoPrice']);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
ok so the line with the error is:
My guess is that it should be:
if (true && ((sizeof($this->Items) > 0) && ((isset($_SESSION['PromoCode'])?$_SESSION['PromoCode']:"") == $_SESSION['PromoDiscount']))) {
it looks like you had extra quotes around one of the values.
psychobilly1165508
Thanks Ray, I just caught that myself. See my post above.
psychobilly1165508
Ok, I fixed the syntax error. The dynamic coupon actually works, but it's only "seeing" the last coupon entry in the database. Theere are 3 different coupons in the database, so I'll need to figure out a way to check against all records.
Any ideas?
