Security Assist behaviuor not applying
Thread begun 4/17/2009 9:19 am by mark.hay302689 | Last modified 4/17/2009 9:44 am by Ray Borduin | 2208 views | 1 replies |
mark.hay302689
Using DW4 & Security Assist 1.1.7
I've had two issues with S.A. today (I've only used it limited in the past) - Namely selecting the random password binding & encryption do not apply the behaviour in the WA_SecurityAssist directory - Somehow by removing & redoing the page again I managed to get the extention to put the SHA1 script in to the directory but I can't get the extension /WA_RandomPassword.php script to apply therefore I get the "Warning: require_once(../WA_SecurityAssist/WA_RandomPassword.php) [function.require-once]: failed to open stream" error _ I've applied the 'email' password script fully as per tutorial and all seems well and I've uploaded the whole site but still this file is missing from my local site - Any one with and idea of where its all going wrong?
mark
Not sure. Try using the bindings panel to add another random password binding. It is supposed to add that file to your site and create the include reference at the same time and it appears the file was not created properly from your description.
If you continue to have problems, please post a support incident since it could be a bug of some sort that somebody will need to look into further.
