eCart out of memory error at line 953
Thread begun 4/16/2009 7:36 am by johnlanglois | Last modified 5/15/2009 6:21 am by Ray Borduin | 7387 views | 14 replies |
johnlanglois
I upgraded to eCart 4.16 by uninstalling 4.15 and installing 4.16.
When running the checkout wizard I now get an out of memory error on line 953.
I have 3GB Ram, so I don't really think that is the problem.
Has anyone seen this error?
What is the file referenced in the error? I can try to take a look at it and see if I can spot what might cause it. You will probably want to open a support incident too since this is likely some sort of bug.
What version of DW and what OS are you using?
neo314
I am getting the same error on the insert checkout form wizard on the Finish button. It is the same error twice and my available RAM plummets. Here are a couple of screen shots. Vista x64 w/ 4GB RAM. CS3.
Are you adding the wizard to a template page? Is it a new page or an existing page?
Please submit a support incident. This is likely a problem with your page, template, or enterd values of some sort, but we will need to have an engineer debug it with you since it is not a known issue.
neo314
It is a new page, but the template has been applied to it. I will try to add it to a page and then apply the template and see what happens...
How much content is on the template page? This seems like it could be caused by an extremely large template page?
neo314
Not much. It is a rounded corner layout with no menu single column...
Were you able to get it to run without the template? You may want to submit a support incident with the files to help reproduce the problem. This isn't a known issue, but if we can reproduce it we can probably fix it, so if you can get us the files to help us reproduce the problem that is a good first step in getting it solved.
neo314
Whoops I moved past this before I saw your post. I hope my last response helps. I ran the wizard with the template applied.
Odd. If you figure out the steps to reproduce the problem I would be interested to find out. I doubt it is just the cartID vs session id thing, but anything is possible I guess.
Once we reproduce it we can find a solution.
