Javascript Error
Thread begun 10/26/2009 11:04 am by nicolelagden329266 | Last modified 11/17/2009 2:48 pm by ccubed_9926864 | 11216 views | 20 replies |
nicolelagden329266
Javascript Error
I am also getting a JavaScript error when I open up the Security Assist Wizard in Dreamweaver CS4 on a mac. I have read other posts where the advice has been to follow the steps on this page:
146/
I have tried all of these steps and I am still getting this error (attached), if I click OK I then get the next error.
Is there anything else I could try?
double check that you have correctly set up a dynamic Dreamweaver site. See the following for more information:
151/
Make sure that the local path to the site folder contains only web safe characters, avoid periods or other special characters in the folder names leading to the site files.
Do you have a dynamic page open in Dreamweaver when launching the security assist wizard?
nicolelagden329266
Thanks for the reply.
Yes that's all fine, unfortunately it's still not working, Data Assist seemed to work fine, but I still get error messages when I try and open the Security Assist Wizard. Always the same first one, but when I click OK, the second error message seems to change slightly (attached).
What version of SecurityAssist do you have installed?
try uninstalling it from the extension manager, then installing the latest version that is available from the Download center.
nicolelagden329266
Unless it's changed over the last couple of days I have version 1.1.8. I have already tried removing it from the extension manager and re-installing after reading other posts, unfortunately no joy!
I have created a support ticket so we can take a look at the issue. To edit your support ticket, please log into your support history:
wbrooks199805
Having same issue
Please add me to the list of people that gets help with this..I am having the same issue.
This issue appears to be with SecurityAssist and Power PC Macs. If anyone else runs into this, please post here and I will get the fix to you.
chris373619
javascript error
Hi Jimmy
I have the same issues on my powermac. I just tried all the other fixes in this post and I still have the problem. Can you send me the fix also?
uri_zen377507
Security Assist - JS Error onload
I cannot load Security Assist 1.1.8.
- JS error on load
- cache file cleared
- dynamic page open
running Mac 10.5.8 PowerPC
