Is there a way of updating metas from one file ?
Thread begun 10/24/2009 1:04 pm by mikeybabe | Last modified 10/24/2009 2:55 pm by anonymous | 1568 views | 1 replies |
mikeybabe
Hi I have CMS working well but clients are interested in
a single file that will update meta files on all pages ?
How can this be done ?
Any ideas ?
anonymous
Are you asking about meta files or meta tags (such as keywords)?
If it is meta tags such as keywords, then yes... you could create a page called, say, "header code" in which you are going to have all the elements you may want to update dynamically in the header code... and then just add the PHP echo statement as directed in the place where your keywords would go. If you wanted to have all the pages have a different set of keywords, then you would simply need to add more content areas to update in your header code page on the CMS side.
Best regards,
Brian
