How to uninstall (or disable) iRite 1.0.2
Thread begun 10/23/2009 2:23 am by stevenc330599 | Last modified 10/27/2009 5:29 am by stevenc330599 | 2350 views | 3 replies |
stevenc330599
I have purchased HTML Editor and am now trying to either uninstall, or disable and then uninstall, iRite 1.0.2 prior to installing the new HTML editor.
Every time I attempt either of these courses of action the Adobe Extension Manager claims that Dreamweaver CS3 is using various files (either *.gif, or *.html files) in the 'Memento' or 'RichTextEditor' subfolders below the 'AppData/Roaming/Adobe/Dreamweaver/Configuration/Sharesd/WebAssist' folder.
In reality Dreamweaver is not open and I have deleted the Dreamweaver 'WinFileCache9999.dat' before attempting to use the Adobe Extension Manager.
Is there any easy way of manually uninstalling iRite? I do not really want to have to re-install 38 other extensions that I have.
Steven.
office377308
restart
If it's Windows:
I needed to first delete Irite, then restart my PC because Vista wouldn't release some of the DW - dll's from its memory.
Hope this helps
anonymous
Steven,
If you just go into the extension manager and hit remove iRite, you will not have to re-install everything else (unless there is something greatly wrong with your entire system - which I doubt).
stevenc330599
Uninstall iRite
Thanks 'office377308'!
The trick of rebooting the system and then not starting Dreamweaver, but launching the Extension Manager worked.
Steven.
