MenuWriter2
Thread begun 4/14/2009 4:12 pm by ljs | Last modified 4/21/2009 9:51 am by arobinson | 4951 views | 7 replies |
ljs
MenuWriter2
Hello. I just download MenuWriter2 upgrade. When I attempt to open in Dreamweaver, two screens automatically open: the Activation screen and the Insert New Menu screen. Both are completely grayed out. The Insert New Menu just keeps "loading" without ever actually loading. Does anyone have any ideas why this is happening? Thanks.
Loann
Is this DW8? We have found a bug in the serialization in DW8. If you post a support incident with your contact information they will send you a resolution for this issue.
ljs
MenuWriter2
Yes, it is DW8. Thanks Ray for the quick reply. I'll do that.
Loann
sbaker287120
Did it work?
Originally Said By: ljs
Loann
I'm having some problem.
cheers
We should have a dot release to address this problem available later today. If you need an immediate fix, please post a support incident.
Hervé
when do you intend to correct this issue
Hello,
on the 16th of april you wrote : "We should have a dot release to address this problem available later today."
i just install this new extension on dmx8 today and i encounter same problem. i'm no more able to use menu writer 1 and i never succeed to activate menu writer 2.
when do you intend to publish your dot release ?
regards
Hervé
I apologize, in our final round of testing another error was submitted through support with uninstalling version 2 interfering with other extensions that we thought we should address first. We are back in the final stages of testing and should have something out very soon. Posting a support incident is still a quick way to get a resolution before the update is made available if you are pressed for time.
Anna Robinson
CSS Menu Writer 2.0.1 is available
The dot release to fix the activation bug for DW8 users has been released. You can access it from your order history.
