Tax and nontax
Thread begun 4/14/2009 1:55 pm by stevesmith373400 | Last modified 4/14/2009 2:58 pm by Ray Borduin | 2727 views | 3 replies |
stevesmith373400
Tax and nontax
Can anyone guide me as to how to set the cart up if some items are taxed and others aren't. In my products table I have a column with yes or no if the item is to be taxed. I thin I would like to do this as a server side calculation but the eCart help and calculations help are not very helpful. Does anyone know how to do it and where in the cart to put it?
I would add a column to the cart called "Taxable"
Then set its value to either 0 or 1 if it is taxable.
Then create a calculation:
TotalTaxable = [TotalPrice] * [Taxable]
Then you can create a tax charge based on the total of that calculated column.
stevesmith373400
So when you add the column to the cart, what do you set the output type as?
A Number or integer since it will be zero or one.
