Got error and can't use CSS Sculptor 3
Thread begun 10/20/2009 1:16 am by Jedt3D | Last modified 10/21/2009 10:17 am by Jedt3D | 2900 views | 4 replies |
Jedt3D
I've remove CSS Sculptor 2.0.5 from Extension Manageer. Then Install v3.
I've open DW with a blank project (PHP, CFM) then after activate the serial. I've the error as attached and blank screen of the extension window. Then nothing happen.
What can I do now?
wacs_quickinsert.htm
hasAutoSave is not defined.
That what is said :(
Jedt3D
My system:
- Mac OS X 10.6.1 on Intel
- DW CS4 10.0.0.4117
delete the Dreamweaver Cache file from the users configuration folder:
mbruges300005
Same problem
Just got the same problem and on reading this post could repair.
Now the new CSS Sculptor 3 is working on my Mac. using Dreamweaver CS3.
Jedt3D
Hi, Jason
Thank you very much. But my case, I can't find the cache file name MacFileCachexxxxxx.dat. It's weird but seems like my Configuration folder is not in a good condition.
My solution is to reinstall every extensions. The fastest way without waiting a night to uninstall extensions on Mac is .....
1. Close every Adobe app.
2. Rename "~/Library/Application Support/Adobe/Dreamweaver CS4/" folder
3. Open Dreamweaver CS4 again and it'll create the new Blank folder, then quit
4. Open Extension Manager CS4 again, it'll have no extensions at all.
5. Reinstall each extension, by release date if possible to find.
6. Viola! My problem is gone!
Not a good solution but work for me right now.
