action when subscription expires
Thread begun 4/14/2009 6:15 am by glmcps295424 | Last modified 4/14/2009 6:24 pm by glmcps295424 | 2687 views | 2 replies |
glmcps295424
Filtering access to pages by subscriber is working fine.
subscriber table includes expiredate and expired (Y/N) fields.
Can someone suggest steps to coding system so that the expired flag gets set to Y if the date is past the expiredate.?
assume server behavior code is required.
Does it belong in login page? or the successRedirect page?
Thanks for your time,
Gregg
I would just create a view and calculate the Y/N value from the database directly.
SELECT *, (ExpDate < Now()) as IsExpired FROM table
or something similar to that. No reason to update the field if it can be calculated from fields that are already updated.
glmcps295424
Ray,
Once I got the dates set up properly , I used the search with the results page to find records with an expiration date < date entered in search field. It's not automatic like I wanted but should work ok.
Thank You,
Gregg
