Discount Codes
Thread begun 10/14/2009 6:06 am by Alf | Last modified 11/24/2014 9:42 am by Jason Byrnes | 11034 views | 17 replies |
Alf
Discount Codes
Hi
First Question
can you get get discount codes from a database? I wanted to extend my CMS for the client allowing them to create discount codes with different discounts (i.e discount code 'Forces' gives 10% off sub-total - discount code 'Wholesale' gives 10% off sub-total)
Secondly Question ...more important....
Can some one tell me how to add a text field for customers to add a discount code and how this can be activated when they click 'update cart'?
Thanks as ever
Alf
First off, you should follow the solution recipe for static coupon codes to get coupon codes working. That tutorial can be found In the Solution Recipes section of the eCart Support Page titled "Creating a Coupon system for your eCart store":
ecart/
To convert that to be database driven:
1) Create a table in your database to hold the coupon codes. it should have a structure similar to:
couuponID - Auto Number, Primary key Column.
couponCode - varchar
couponAmount - double
To add a coupon code of "test" that will give a 10% discount, you would create the follwoing record:
couponID | couponCode | couponAmount
1 | test | 0.10
2) Next is to add a recordset to the page to lookup the coupon amount based on the code the user enters.
On the server behaviors panel, click the plus button and select Recordset. In Simple view, set the record set to use the coupon table we created. Set the name of the recordset to "rsCoupon" In the Filtering Section, set it to filter the couponCode column Equal to the Form Variable txtPromoCode, this is name of the text box created in the coupon code system tutorial.
3) Now we need to create another session variable to hold the discount amount. On the server behaviors panel, click the plus button and select eCart -> General -> Set Session Value. Set the trigger to "recordset rsCoupon Not Empty". Set the name of the session variable to "PromoAmount". Click the lightning bolt next to value, expand the rsCoupon recordset and select the couponAmount column.
4) The PromoCode session variable needs to be modified as well. Set the trigger to "recordset rsCoupon Not Empty" so it will only get set if the promcode sexists in the database.
5) The last step is to modify the Promotional Discount rule in eCart. Remove the "If Session variable == WebAssist" triger.
Add a new trigger "Session variable exists "PromoCode""
Add another trigger "Session variable exists "PromoAmount""
Then Modify the charge rule "Bases on Cart SubTotal "Times" "$_SESSION['PromoAmount']"
so that the discount will use the value stored in the session variable from the database.
Alf
Discount Codes
Hi Jason
Thanks for the feedback, I have the code working manually, still got to tie it in with the database.
I have a different Discount Question.
I have a client side cart where they take phone orders
They want a free text box where they can input discounts (numerically) for friends an family
I've set this up adding a session 'FriendsDiscount' on the cart page
if((((isset($_POST["FriendsDiscount"]))?$_POST["FriendsDiscount"]:"") != "")) {
$_SESSION["FriendsDiscount"] = "".$_SESSION['FriendsDiscount'] ."";
however I'm having problems with the discount code.
I have the following:
Condition: Total number of items > 0
Calculation: Based on the cart subtotal -minus- $_SESSION['FriendsDiscount']
If I type a discount of 10.00 into my FriendsDiscount text field for a product costing £50.00 I get a total (after discount) of £10.00
Any suggestions
thanks
Alf
Your setting the value of the Friends Discount Session to be equal to the value of the ffreind Discount Session:
should'nt it be equal to the value of the friends Discount form element?:
$_SESSION["FriendsDiscount"] = "".$_POST["FriendsDiscount"] ."";
sounds to me like somewhere along the way, the friends discount session variable got set to 40.
In future for trouble shooting, I find it helps to echo values to the page so you know what is being used behind the scenes:
<?php echo("The Session FriendsDiscount is equal to: ".isset($_SESSION["FriendsDiscount"])?$_SESSION["FriendsDiscount"]:"Nothing"); ?>
<?php echo("The Post FriendsDiscount is equal to: ".isset($_POST["FriendsDiscount"])?$_POST["FriendsDiscount"]:"Nothing"); ?>
Alf
Screen Grab
Hi Jason
thanks for the speedy response
I've taken you advice and echoed the session (please see image attached) but still get a strange figure from the discount rule
As you will see:
the subtotal is 79.00
the discount amount entered is 20
the discount result returns -59.00
the delivery charge is a flat rate of £7.99
giving a total of £27.99
I wanted a total of 86.99
thanks
Alf
It looks like you set up your discount as:
Subtotal minus 20
when really you should just use:
Flat Rate: 20
Alf
discounts
Hi Ray
Its not a flat charge
Its manually added at the discretion of the client
What I've noticed is if I enter the discounted price that I want the user to pay in the FriendsDiscount field I get the the right info. in the rest of the cart - see diagram
In the FriendsDiscount I typed in the discounted price I wanted them to pay in this case 69.00
What I'd like is for this to work in reverse so I can type in the amount of discount I want to give them
thanks
Alf
Alf
solved
Hi Ray
I should have listen more carefully
Flat rate is the solution
thanks again
Alf
Jamie
This post has been deleted.
Alf
Discounts from database
Hi Jason
I've followed the instructions as best as possible but get the following code when setting the CouponAmount session and the rs being not empty
PHP Notice: Undefined variable: totalRows_rsCoupons in C:\inetpub\wwwroot\littleme\phone\cart.php on line 29
Any suggestions?
ecart/
1 | test | 0.10
