drop down box
Thread begun 4/11/2009 10:24 pm by Vikingbear | Last modified 4/16/2009 2:08 pm by Ray Borduin | 3357 views | 3 replies |
Vikingbear
drop down box
How do you use the Contact Form Solution on drop-down boxes?
The options given really only work on TEXT fields...
<input name="Contact_Name" type="text" id="Contact_Name" class="formInput" value="<?php echo(ValidatedField("contact","Contact_Name")) ?>" />
<input name="addblock1" type="text" id="addblock1" style="display:none" value="" />
<br />
if (ValidatedField("contact","contact")) {
if ((strpos((",".ValidatedField("contact","contact").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<p class="emailFormError style1">* Please provide your Full Name.</p>
<?php //WAFV_Conditional contact.php contact(1:)
Select fields should behave the exact same way as text fields. What have you tried? Where are you running into trouble?
Vikingbear
Drop Down Box
Hi, Ray
The problem is the VALUE field
in a dropdown box, it is not what the user types in but a set value for each option..
Regards, Ken
Are you using Dreamweaver? use the dreamweaver properties panel to set the values in the list. Set the selected value in that interface to: <?php echo(ValidatedField("contact","Contact_Name")) ?>
