product detail page not passing correct item number to cart page
Thread begun 4/10/2009 11:45 am by robert329616 | Last modified 4/10/2009 12:05 pm by robert329616 | 2450 views | 2 replies |
robert329616
Hello.
An issue has popped up that was resolved(?). I changed all references in my database and PHP code for the Item Number (number to text) so I could include alpha numeric.
When I select a product from the category page and go to the product detail page the item number (T55548D) populates correctly. When I select add to cart and go to the cart page the item number shows up as 0. Also 000550 shows up as 0. Item numbers that start with 1-9 appear properly. I went back through the code but cannot seem to find the issue.
The site is live at www.24sevenpetavenue.com. The cart and product detail pages are located at: /cart.php and /product.php.
Any help would be greatly appreciated.
Regards,
Rob
Make sure the cart column is marked as text and reapply the add to cart server behavior on that page. That should fix it.
robert329616
Ray,
That did it, thanks for the help! I can't believe how easy it was...
Regards,
Rob
