Authenticate User - Session Variable Not Being Set
Thread begun 4/09/2009 5:07 am by jon245706 | Last modified 4/09/2009 7:11 am by Ray Borduin | 3165 views | 1 replies |
jon245706
I am using the WA Authenticate User extension.
I have noticed that if (in the extension) I try to get it to set a session variable from a database Boolean field, the session variable only gets set if the value is True. If it is null then the session variable doesn't get created at all.
I think the code affected is:
For idx =0 To UBound(WA_Auth_Parameter.Item("sessionColumns"))
Session(WA_Auth_Parameter.Item("sessionNames")(idx)) = cStr(WA_Auth_loginRS.Fields.Item(WA_Auth_Parameter.Item("sessionColumns")(idx)).Value)
Next
The CStr (on the field value) seems to be causing the problem, as you can't use CStr with Null values.
Does anyone have a workaround for this ?
Remove the cStr?
or maybe add an IF statement to catch the null case.
