Check for duplicate email address as well as username (user registration)
Thread began 10/02/2009 4:01 pm by phil | Last modified 1/16/2010 11:30 am by dan361748 | 4149 views | 23 replies |
phil
Hi all,
This thread might be totally pontless if the extension actually performs this functionality, but I couldnt find a menu to let me check that the registrants email address doesnt already exist as well as username. Is it possible?
Checking for a duplicate email address in the database is fairly essential functionality for me. I never want the same email address registering different accounts.
I modified the code which checks the database for a duplicate username so that it also checks for a duplicate email. It may be of interest to others.
You will need to replace 'u_email' and 'u_username' with your own email/username field name's.
You could easily modify it to check that the person registering doesnt have the same pet, car, street address etc as anyone else already registered too (if you wanted), as well as multiple other checks.
// *** Redirect if username or email exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
//check username
$MM_dupKeyRedirect="register.php?userExists=true";
$loginUsername = $_POST['u_username'];
$LoginRS__query = "SELECT u_username FROM users WHERE u_username='" . $loginUsername . "'";
mysql_select_db($database_watestConn, $watestConn);
$LoginRS=mysql_query($LoginRS__query, $watestConn) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//check email
$MM_dupKeyRedirect_email="register.php?emailExists=true";
$loginEmail = $_POST['u_email'];
$LoginRS__query_email = "SELECT u_email FROM users WHERE u_email='" . $loginEmail . "'";
$LoginRS_email=mysql_query($LoginRS__query_email, $watestConn) or die(mysql_error());
$loginFoundEmail = mysql_num_rows($LoginRS_email);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
}else if($loginFoundEmail){ //if there is a row in the database, the email was found
$MM_qsChar = "?";
//append the email to the redirect page
if (substr_count($MM_dupKeyRedirect_email,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect_email = $MM_dupKeyRedirect_email . $MM_qsChar ."reqemail=".$loginEmail;
header ("Location: $MM_dupKeyRedirect_email");
exit;
tom92909Beta Tester
Yes, I'm actively working on something similar. I need to offer a signup using an email address, but the same is true, I need to verify if the email address already exists in the database.
Is there a tutorial, recipe, or sample for such?
Would a Server Side validation be best for this? If so is there an example of how to implement this?
I would agree that this is an essential functionality for anyone that gathers/collects email addresses.
First you need to create a recordset to see if the email or username existst in the database.
If you want to be able to display a different message if the user name is already in the database, you need to create two recordset. One to check for the user name, one to check for the password.
crate the first recordset, named usernameLookup. Set it to filter the username column on the username form element.
Create the second recordset as emailLookup, Set it to filter the email column on the email form element.
Then add server validation. For the username, use Numeric validation. Set the server variable to "$totalRows_usernameLookup", set the minimum to -1 and the max to 0. same for the the email, use numeric validation. Set the server variable to "$totalRows_emailLookup" the minimum should be set to -1 and the max set to 0.
Setting the validation this way will check that either recordset is empty.
PaulBeta Tester
Gave this same issue some thought some time ago and decided for simplicity and effectiveness, to use the email address as the username during registration.
This way, you've got a unique username, which is validated, and you have an email for forgotten passwords etc.
You may, if not already done so, wish to consider this option.
Paul.
phil
I thought of that and it would work nicely in many situations (such as e-commerce). However if your site has a social-networking aspect then users will want unique display names when making posts etc, so a workaround will always be needed.
It would be good to get unique checks on username AND email within the WA extensions, though it is fairly easy to create your own workaround as above.
dlovas275157
I set up a similar server validation to check that both username and email are unique upon registration. Vaildation works, only one problem.
When the validation catches a duplicate entry on either the username or email field, the form reloads with the validation prompt, but the form is cleared out and the user has to re-type all the info in again in order to try to register again. Makes the registration process difficult for users.
Any way to preserve the form data? Anyone else have this issue too?
When validation fails, the fields that pass validation are stored in the Validated Entries binding group.
Bind the initial Values of the form elements to the corresponding element in the Validated Entries binding group.
dlovas275157
That worked. Thanks.
bryan107833
Validation working but then always gets error
I have added the 2 record sets etc. and it seemed to be working except that it always now defaults to the "Email exists page" even when it does not. I do have the validation above the Insert Record Behavior. Any ideas? Thanks.
dealer_insert_082009.zip
line 84:
$WAFV_Errors .= WAValidateNM(totalRows_emailLookup . "",-1,0,"",",.",true,2);
needs to be changed to:
$WAFV_Errors .= WAValidateNM($totalRows_emailLookup . "",-1,0,"",",.",true,2);
