Adding More Columns in eCart Object?
Thread begun 4/08/2009 10:36 am by Art | Last modified 7/16/2010 7:42 am by Ray Borduin | 9808 views | 16 replies |
Art
My site has many pages and I am faced with the fact that I need to add a few more columns to the eCart Object. I'm building a coupon discount that is based on the category of the item but I don't currently have that built in. The problem, of course, if I do this and upload it, none of my pages will work and I'll have a mess on my hands. Consequently, what I need to do, before uploading the cart definitions, is go into each page and fire up the eEcart behavior in each page.
NOTICE: I wish this part (above) could be built into an include so by updating one you update all...
1. Is there an easier way of doing this without having to go into each page and fire up the eCart behavior?
2. Can I just add a couple more generic columns that aren't linked to anything so I don't have to do this all over when the case arises?
You only have to update the add to cart buttons to add content to those columns. I don't see how having placeholders would help... if you add a column you will need to update the add to cart server behavior to specify the contents.
Art
I don't think I understand
I don't think I understand your response.
Perhaps restating will confirm my intention...or not...
In order to do the discount on category, I need to store the category id somewhere/product. I could do a plain old session variable but it wouldn't be tied to each row product added.
So, when I open the ecart window, I see the "General, Columns, Calculations, Discounts, Charges, Taxes" tabs. When I go to "Columns" I see a list of items like "Price, Name, Id, weight..." that are added/line when a product is added. I need to add one more "Column" here called "Category" that will record the category of each product and only those products will get a discount of 25%.
My past experience tells me that if you change the Columns by adding one more, and if you post the "WA_eCart_Definition_VB.asp" and "name_eCart_VB.asp" that get updated when you change anything in the ecart, the site dies and you get a major error.
The only way I know to do this is to go into each page and update the (as you said) the add to cart page and I'm wondering if this is the only way. I have a lot of pages and I want to avoid this.
Is this clear?
By the way, what would the rule look like?
I know it would be something like the following but what would it look like if I ONLY want it to apply to items that are in that category and not in others?
25% off if category is (categoryID)
If you don't have an active session the only thing that needs to be updated is the add to cart buttons. Since you are adding a column you would want to update those anyway to insert the correct category ID... maybe we keep going over eachother's head but it seems this would be necessary even if no errors occured without it.
Art
You're right, I would have to update each "Add To Cart" item on the site.
Any ideas on what the "expression " would look like for this? I don't think the regular options offer what I need for this.
Art
Or, do you think this would fit into the normal scope of WebAssist's tools.
I'm afraid I don't understand the question.
Art
Sorry, let me try again.
Let's say I have 3 categories of products
01, 02, and 03
I want to have a coupon apply a discount on products in group 03 at checkout time.
What would be the best way to do this in WA?
1) What Server language? (I'll answer in php)
Most likely you would add a column to your cart for the category.
Then you would add a calculation like:
TotalDiscount = (([category] == '03')?([TotalPrice] * 0.25):0)
Then add a discount that is equal to the total of the TotalDiscount column in the discount tab.
Art
ASP vbscript
how different would the calculation be?
