Using more than one Universal Email server behavior on a page.
Thread begun 4/08/2009 6:47 am by sandy170299 | Last modified 9/30/2016 11:03 am by Ray Borduin | 6551 views | 7 replies |
sandy170299
Can I use more than one Universal Email server behavior on a page. I want to submit an email to the web site owner and submit a thank you email to the person who filled out the form.
Yep. Just make sure not to set the redirect until the final email is sent.
sandy170299
I had that part working, and put the redirect on the 2nd server behavior, but I'm getting an error message now when the page loads.
hirebillform.cfm
I think you are missing a quote in:
& ToString(IIf(isDefined("Form.email"),"Form.email",DE("))) & "")>
should be:
& ToString(IIf(isDefined("Form.email"),"Form.email",DE(""))) & "")>
sandy170299
Yup - that worked. I swear I didn't touch that part of the code myself. I'll try to remember what the fix was in case it happens again :) Is this possibly a bug in the ColdFusion server model?
sandy170299
After I went back and changed something in the server behavior, it defaulted to the single quote again and I'm getting the "Missing argument name" error again. In fact, it stripped the double quote from both fields, the from name and from email fields. Is this something that you think WA might fix in the future?
tony
Hi Ray,
I have the same problem and found here the fix.
But I have a specific question regarding this argument:
I have a form that submits on BUTTON XXXXX IS PRESSED.
Then, two emails should be sent:
1 - with attachment to my email account;
2 - without attachment to the customer that filled the form.
I removed the "go to page" destination on the first created universal email Server Behaviour.
Will the trigger (button XXXXXX pressed) be executed for all two universal email SB?
TIA
tony
Yes, that would work.
