Inserting Current Date into MySql
Thread begun 4/05/2009 10:18 am by zuffster370186 | Last modified 4/06/2009 9:41 am by Ray Borduin | 2465 views | 1 replies |
zuffster370186
I have never been able to do this but how does one record the current date of a new registered user into MySql? I have set up a column in my database 'user_reg_date' but when a new record is put into the database, the date field only shows '0000-00-00'. I need the current date to be recorded in the user_reg_date column when someone registers. I would appreciate the help
The easiest way is to set the field as a timestamp and set its default value to: CURRENT_TIMESTAMP.
This way the database will do it for you.
Another option is to use <?php echo(date('Y-m-d H:i:s')); ?> as the value for that column.
