Redirect based on cookie value
Thread begun 9/21/2009 7:59 am by hirshj389512 | Last modified 9/22/2009 1:03 pm by hirshj389512 | 12087 views | 10 replies |
hirshj389512
On of features is the ability to redirect to a web page based on a cookie value
I can notfind any documentation for that.. in fact there is virtually no documentation
I am using a swf intro for a web site (no log on) and want to be able (if possible) to avea cookie remember that the person does NOT want to see movie again
Dani Chankhour
I will out line the steps you need to take to set up the redirect:
- in DW open the behaviors panel (Window -> Behaviors)
- Click the + button and look for WA Cookies Toolkit, and then look for 'Redirect Based on Cookie'
- in the Wizard you can type the cookie name and the url where you want the user to be redirected to.
This assumes that you already have a cookie created.
hirshj389512
No Joy
This is what has been generated by your extension
if ($_SERVER["REQUEST_METHOD"] == "POST") {
setcookie("NoShow", "1", time()+(60*60*24*30), "/", "", 0);
<script src="WA_Cookies/Cookies.js"></script>
function WA_cookieRedirect(CookieObj,Location,Alike,CookieName,CookieValue,RedirectTo,NewWindow) {
if ((CookieObj.getValue(CookieName)==CookieValue)==Alike) {
if (NewWindow)
window.open(RedirectTo);
else
Location.location.href=RedirectTo;
</script>
</head>
<body>
<form id="form1" name="form1" method="post" action="">
<label>
<input name="NoShow" type="checkbox" id="NoShow" onclick="WA_cookieRedirect(WA_CookieObj,document,false,'novideo','1','/mainindex.html',false)" <?php if (!(strcmp(((isset($_COOKIE["NoShow"]))?$_COOKIE["NoShow"]:""),1))) {echo "checked=\"checked\"";} ?> />
Skip Video</label>
</form>
IfI check the box it jumps whoppee....I would take it from the script language that i Have created a server based ever..
I want to create a client based cookie so wnen client comes back it does what he wants
Dani Chankhour
The redirect needs to be done on the body tag of the page, so the redirect will happen when the page is loading.
Please select the body tag and apply the redirect.
In addition , you will need to set the cookie value when the form is submitted. So when the form tag select, set a cookie a value (Behaviors -> Cookies Toolkit). This will set the cookie value when the form is submitted.
I have attached a working example which could help you with the steps.
hirshj389512
divine revelation
Ican see the mistake I made on timing on the body
the submit process I have no idea were it came from, I see noting close to it in what you guys call documentation and in fact itis dramatically different from previous instructions
the only way it will appear I can duplicate is to hand code
hirshj389512
mystery script
ok I was partly wrong
feeding te file back into the extension..I was able to see ow it works granted it is nothing like any documentation i can find or the previous direction
the stil leaves the question of the following scripy
<script name="WACookieDis">
document.write(WA_CookieObj.getValue("new"));
</script>
and were did that came from??? It obviously is an important player as it is get the value of the variable...
Dani Chankhour
You can just ignore that code. That code writes the value of the cookie to the page. I only added that code when i was testing to see the value of the cookie.
Sorry for the confusion.
hirshj389512
aah
OK...I now see..your example helpedbut completely contradicted that early instructions and documentation
hirshj389512
Documentation a little week
Ok in the last 24 hours I have recreated your example which does work
The documentation provided on the web site is useless. The tip you provided on the body helped
this is what i finally did
In Dreamweaver CS 4
create php page
add form in body (Insert -> Form)
change method = post
name "your form"
add form ID in properties
add form label (Insert->form->Label)
add checkbox inside value tag)Insert->Form->checkbox
Leave Type checkbox
Set Name "urcheckbox"
Set Value "urcheckbox"
add form value tag (Insert ->Form -> Label)
add button (Insert ->Form -> Button)
chnage type to submit
set value = submit
Higlight the button
use properties to add id "submit"
select form up to first label
use behaviors
From the Server Behaviors panel, choose Add.
Choose WA Cookies Toolkit > Set Cookie Value. OnSubmit
enter cookie name ("urchoice")
select body
goto behaviors
Choose WA Cookies Toolkit > Redirect Basedon cookie
select cookie (name as in above)
set cookie value to true
set destination
its done
The on line documentation indicated that there was no problem if you didn't have a form
not necessaryily true..
You said that you assumed that cookie was already made... if so you don't get the code you generated
the cookie is apparently created when value is first set
Dani Chankhour
In regard to documentation, all of our documentation for Cookies Toolkit will be listed here:
cookies-toolkit/
I understand that we don't have documentation available for how to set a redirect based on a cookie. But i think from here i think we should be able to create one.
I will inform our documentation team.
