eCart per user
Thread begun 4/04/2009 6:53 am by jon245706 | Last modified 4/06/2009 7:28 am by jon245706 | 4409 views | 4 replies |
jon245706
eCart per user
i have created a login system using WA Security Assist, so different users may be able to login and out on the same machine.
Each user can use an eCart to save items they are viewing.
Unfortunately the same eCart shows for each user !!!!!
Why is this ? ... I can't seem to set eCart to start a unique cart per user.
HELP !!
eCart is stored per session. If you want it to be reset for each user you could clear the cart during login.
jon245706
Hi Ray
Thanks for the info.
The problem is that I want the user to be able to see the contents of their cart when they return to their login page. That could be after a timeout, or after a week.
You will have to store the cart in the database and retrieve it from the database to do this... these are both available as server behaviors.
jon245706
of course... doh ... i will check them out. thank you
