New to working with DataAssist
Thread begun 3/03/2009 11:58 am by pdesignz | Last modified 3/03/2009 12:38 pm by Ray Borduin | 2826 views | 1 replies |
pdesignz
Hello,
I am new to working with WA DataAssist. In the past I have used pre-built ecommerce solutions like BV Commerce and AspDotNetSorefront. These solutions had built in cms, online store displayed in columns not vertical display, protected sections if needed and more. I have the majority of WA products and wanted to see if I was able to do this myself using WA products. I ran through the Data Assist tutorial and had no problems, but am not sure how I would use Data Assist to create product pages in multi column format and then how would I integrate that to ecart, security assist. Also when viewing tutorial and using search, If I choose a category like CD or gear and then go back to view products it still displays previous category, only way to clear is run new search and not choose a category to display. Is there a way around this and is there a way to also show a default category on page load before any type of search is run. What I am wanting to do is create an online store, products would be displayed in multi colum view, be able to navigate by category, not a seperate page for every product like gear.asp or music.asp but all load on same page like products.asp?id=1 or 2 and this would change on category selected. Also have backend with protection that I would then use security assist and there I would use the Admin pages from Data Assist to update, edit or delete products in main site.
I'm not sure how to answer this question. It should be possible to do what you are explaining.
When you run the dataassist wizard it has an option to display in columns, and integrating the other tools is covered in the tutorials of those tools and difficult to sum up in a forum post.
