DataAssist INSERT after Validation passes
Thread begun 4/03/2009 7:18 am by mshappell237278 | Last modified 4/03/2009 8:48 am by Ray Borduin | 2800 views | 1 replies |
mshappell237278
I would like to insert a record to the database IF all validations from WAValidation Toolkit pass but I'm not sure how to select the trigger. Should I simply select Any Form Post and then manually change the trigger statement to if ($WAFV_Errors == "")?
Thanks in advance for any input provided.
If you add validation it will automatically stop any inserts or updates. Just make it so it works when no validation exists, then add validation.
