css Menu make code wrong.. need help?
Thread begun 3/03/2009 11:06 am by toleehua356796 | Last modified 4/13/2009 10:04 am by David Stringer | 23600 views | 12 replies |
toleehua356796
i am used the css menu writer & date assist to make the dynamic item Menu. i am follow before your train video to do it. but when i finish the Dreamweaver cs3 Live Data Error
show on the page. Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in C: \AppServ|www\zone|CSSMenuWriter\cssmw_content\menu_41qjlfy92x.php on line 31 & 33
my website: www.yaozone.com
the code:
Line: 31 mysql_select_db($database_connbulesky, $connbulesky);
Line: 32 $query_rsHZ = "SELECT * FROM items WHERE ItemCatID = 1 ORDER BY ItemID ASC";
Line: 33 $rsHZ = mysql_query($query_rsHZ, $connbulesky) or die(mysql_error());
Line: 34 $row_rsHZ = mysql_fetch_assoc($rsHZ);
Line :35 $totalRows_rsHZ = mysql_num_rows($rsHZ);
on the localhost used firefox show the index.php
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in C:\AppServ\www\zone\CSSMenuWriter\cssmw_content\menu.php on line 31
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in C:\AppServ\www\zone\CSSMenuWriter\cssmw_content\menu.php on line 33
i don't know how to fix this. please help?
i used the date: bludskymusic. all the page is make by dateassist. the Menu make by CSS Menu Writer. help me please. i spend tow weeks still dont know how to fix.
please go to mine web site to see. i upload still not working!
www.yaozone.com
Thanks any one can help!
These errors imply that the connections folder is not included or is not referenced properly on the page. Make sure the connections file is correct and appears on the top of the page.
toleehua356796
Thanks so much! I got fix it. But the templates pages (siteassistpro_template.dwt.php) Still don't work. When i used the live date. DW CS3 show on like this:
Warning: require_once(Connections/connbulesky.php) [function.require-once]: failed to open stream: No such file or directory in C:\AppServ\www\zone\CSSMenuWriter\cssmw_content\menu.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'Connections/connbulesky.php' (include_path='.;C:\php5\pear') in C:\AppServ\www\zone\CSSMenuWriter\cssmw_content\menu.php on line 1
Can your tell me again how to fix it. please?
open up the file:
and look at line 1
it appears that an incorrect connections reference is on this page. You would need to either remove or update it.
toleehua356796
ecart add to cart button pick which recordset?
Thanks again to you! I got another question about the ecart.
I follow the ecart “getting_started_guide” finish the index.php > add the ecart object.
But on the product page: ecart add to cart button> General> Properties> look up item ID from the recordset. I don’t know which recordset. I pick?
I open the product page. Widow server behaviors> tow recordset on this page.
Recordset (WADAitems ) follow the AdminSuite_SolutionRecipe video the product page come with.
Recordeset (rsHZ) this one is mine before do the css menu writer & date assist to make the dynamic item Menu. Add on the Menu.php page.
I check this tow recodset is the same:
Filter> itemCatID
Entered Value =1
Sort> ItemID> ascending.
Would you please teach me which recordset I can choice is right one?
I think it refers to the WADAitems recordset. But I really can't be sure because I don't quite understand what you are talking about.
toleehua356796
ecat on the product/ items_Detail page. Heed help ?
Sorry! I need help again for the Ecart:
When I finish the
Product.php page:
Ecart Add to Cart Button.> on the product.php page.
DW CS3 Live Data Error show like this:
An error occurred while requesting the document form the testing server:
Fatal error: Call to a member function GetContent() on a non-object in C:\AppServ\www\yaozone\products.php on line 3
Fire fox show:
Product.php page code:
Line 1: <?php require_once('Connections/connbulesky.php'); ?>
Line2: <?php
Line3: $BlueSky->GetContent(); *********wrong on this Line *********
Line4: ?>
Line5: <?php
Line6: //WA Database Search Include
Line7: require_once("WADbSearch/HelperPHP.php");
Line8 ?>
Line9: <?php
items_Detail.php page:
Ecart Add to Cart Button> on the items_Detail.php page.
The DW CS3 Live Data Error Show like this:
Parse error: syntax error, unexpected T_VARIABLE in C:\AppServ\www\yaozone\WA_eCart\BlueSky_PHP.php on line 10
Fire fox show:
Item_Detail.php page code:
Line 1: <?php
Line 2: //WA eCart Include
Line 3: require_once("WA_eCart/BlueSky_PHP.php");
Line4: ?>
Line5: <?php require_once('Connections/connbulesky.php'); ?>
Line6: <?php
Line7: $BlueSky->GetContent();
Line8: ?>
Line9: <?php
Line10: if (!function_exists("GetSQLValueString")) { *******wrong on this line *******
Line11: function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
Line12: {
Line13: $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
Please help me again! Thanks again to you!
The page with the error is missing:
//WA eCart Include
This code has to appear before: $BlueSky->GetContent();
toleehua356796
still not work. the wrong line go to line10
when i post your toll me the code on page. the wrong line go to line 10. DWcs3 live date show on:
Parse error: syntax error, unexpected T_VARIABLE in C:\AppServ\www\yaozone\WA_eCart\BlueSkyCart_PHP.php on line 10
Before page code:
line 1: <?php require_once('Connections/connbulesky.php'); ?>
line 2: <?php
line 3: $BlueSkyCart->GetContent(); ******wrong code here*****
line 4: ?>
line 5: <?php
line 6: //WA Database Search Include
line 7: require_once("WADbSearch/HelperPHP.php");
line 8: ?>
line 9: <?php
line 10: //WA Database Search (Copyright 2005, WebAssist.com)
line 11: //Recordset: WADAitems;
line 12: //Searchpage: items_Search.php;
line 13: //Form: WADASearchForm;
After post:
line 2: <?php ****** post your toll me the code*****
line 3: //WA eCart Include ********post your toll me the code*****
line 4: require_once("WA_eCart/BlueSkyCart_PHP.php"); ****post you toll me code****
line 5: ?><?php
line 6: $BlueSkyCart->GetContent();
line 7: ?>
line 8: <?php
line 9: //WA Database Search Include
line 10: require_once("WADbSearch/HelperPHP.php"); ??????DW cs3 show wrong on this line ?????
line 11: ?>
line 12: <?php
line 13: //WA Database Search (Copyright 2005, WebAssist.com)
line 14: //Recordset: WADAitems;
line 15: //Searchpage: items_Search.php;
line 16: //Form: WADASearchForm;
line 17: $WADbSearch1_DefaultWhere = "";
line 18: if (!session_id()) session_start();
line 19: if ((isset($_GET["Search_x"]) && $_GET["Search_x"] != "")) {
line 20: $WADbSearch1 = new FilterDef;
line 21: $WADbSearch1->initializeQueryBuilder("MYSQL","1");
line 22: //keyword array declarations
line 23: $KeyArr1 = array("ItemShortDesc");
Please help me again! Thanks!
wrong go to the line 10: see ??????DW cs3 show wrong on this line??????
thanks again!
It looks correct. What is the exact error you are getting?
