Too much space in content div
Thread begun 9/10/2009 2:16 pm by WilliFixit | Last modified 9/10/2009 5:00 pm by Jimmy Wu | 1740 views | 1 replies |
WilliFixit
I have inserted a CSS Form Builder form into a WebAssist template from SiteAssist Pro. When I do so, the form shows up well below the top of the content section, looking like there is a lot of extra space. How do I fix that?
Please see attached png.
If you change the lines similar to these in your FD_NewFromBlank_Default.css file:
form.NewFromBlank_Default li.formItem {
clear:both;
form.NewFromBlank_Default fieldset.NewFromBlank_Default {
clear:both;
to have the clear property be none, the form will be at the top.
clear:none;
clear:none;
You will also have to change the overflow on the content wrapper to be visible instead of hidden if you want the entire form to show.
