EXFold not defined
Thread begun 9/10/2009 3:36 am by kakadong | Last modified 9/11/2009 4:00 pm by Dani Chankhour | 4313 views | 5 replies |
kakadong
EXFold not defined
after i installed
when i want to activate it
it shows
so i can't use it or activate it
it means:
while onload (in WA_Surveyor_Ser.htm ) it occur javascript error
in line 215 (in files c:\........................................................)
EXFold not define
I check c:\program files\adobe\adobe dreamweaver CS4\Configuration\Shared\
the folder structure is that
in .........................\shared\
i don't have the folder which name is webassist .....
OS: XP sp3
DW CS4 (traditional chinese)
So... i can't use the app
can anyone help me????
The file being referred to is located here:
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration\Shared\Webassist\Surveyor\Library
This error may have to do with your operating system. One thing you can try is to shut down Dreamweaver and extension manager and delete the WinFileCache#####.dat file located here:
kakadong
the file structure is like
C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\zh-tw\Configuration\Shared\Webassist\Surveyor\ Library
in my computer .....
only a little change the en-us is zh-tw in my computer....
not only this app but also site assist professional meet the similar problem...
but I'LL try again to delete the file you told me....
if it solves , I'll report here...
Ok, let me know how that goes.
kakadong
pity...
By deleting the file ,it still doesn't make the surveyor work .....
I remove all extensions and install only surveyor .....
it still don't work for me ....
the same problem shows.....
maybe the surveyor don't know the file structure between en-US and zh-TW
so the Shared_Ser.js can't work .....
can you help me to solve this??
by the way , when I install Surveyor ,everything goes ok.. No warning ...
Dani Chankhour
I recommend deleting your config folder. This will explain how to do this:
showpost.php?p=15525&postcount=2
after deleting your config, make sure to only install Surveyor and make sure to have the latest Surveyor version installed.
