Create download button in a Data Assist Results table
Thread begun 9/08/2009 5:20 pm by peter383096 | Last modified 9/28/2009 5:19 pm by neil186288 | 7479 views | 11 replies |
peter383096
I have added a row to my DA table and added a download button with a DFP download behavior. everything is working except it unfortunately downloads the most recent field no matter what download button you press. I need some way of linking the button to the id or the file name...
here is a live version here:
loadingDock_List.php
user: guest@fuelcdi.com
pass: fuelgues
PHP Here:
Thanks in advance
anonymous
Peter, probably the quickest way to do this would be to actually put the download code inside the loop... but make sure you create some sort of incrementing system.
Like set a variable such as: $incnumber = 0
then inside the loop have it increment like: ++$incnumber
then attach the variable to both the name of your download button and your looped download code, so it would look like this:
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if(isset($_POST["'download'.$incnumber"])){
WA_DFP_DownloadFile("WA_DownloadResult1", "uploads", "".$row_WADAloadingDock['fileName'] ."", "[FileName]", false, false, false, "", "", "", "");
<input type="submit" name="download<?php echo $incnumber; ?>" id="download<?php echo $incnumber; ?>" value="Download" />
That way, the file name will populate correctly in the loop and download behavior knows which one to trigger based on the dynamically created unique number you added to each one.
Cheers,
Brian
peter383096
Hi Brian,
Thanks so much for your help. I have a couple of questions, please forgive my ignorance.
to define I have used this code directly before my opening HTML code. is that correct?
//define incnumber variable
$incnumber 0
This is the bit I am having trouble with, I am not sure where this should be.
Below is my repeating region, is that looking ok?
<?php do { ?>
            <tr class="<?php echo $WARRT_AltClass1->getClass(true); ?>">
              <td class="WADAResultsTableCell"><?php echo $row_WADAloadingDock['submitTime']; ?></td>
              <td class="WADAResultsTableCell"><?php echo($row_WADAloadingDock['fileName']); ?></td>
              <td width="90" align="right" class="WADAResultsTableCell">
              <form id="form1" name="form1" enctype="multipart/form-data" method="post"  action="">
("WA_DownloadResul t1");
                if(isset(
WA_DFP_DownloadFile("WA_DownloadResult1""uploads""".$row_WADAloadingDock['fileName'] ."""[FileName]"falsefalsefalse"""""""");
            <input type="submit" name="download<?php echo $incnumber?>" id="download<?php echo $incnumber?>" value="Download" />
            </form>
            </td>
            </tr>
          <?php } while ($row_WADAloadingDock mysql_fetch_assoc($WADAloadingDock)); ?>
Once again thanks!
Pete
anonymous
That looks right... you would want to add the increment code just after the opening "do" tag like this:
<?php do { ?>
            <?php ++$incnumber?>
                if(isset(
            </form>
            </td>
            </tr>
anonymous
Also, you may have to play with the quotes in the post variable parenthesis, as I am terrible about remembering the exact arrangement when concatenating like that... that's where I go into trial and error mode. :)
Cheers,
Brian
peter383096
Hi Brian,
sorry for the lack of reply, i couldn't get this to work so i gave up and just settled for a download in the results page option,
thanks for your help though.
anonymous
Sorry to hear that... I may have some time tomorrow, if you still want it to function the way you planned, you could send me the file and I will play around with it.
afkrennie381204
Hi SOJO, all,
I also need to get this working and have had no luck. Would really appreciate advice on how to get it to work! I have tried every permutation of S_POST syntax under the sun to no avail - the page displays fine but there's simply no file downloading. I'va also tried this using the unique record id as displayed on the same line (as per the other post on this subject with altered syntax that seems correct too - again, page displays fine but no file downloads). Would really appreciated some advice - many thanks. Ann
For the inc example, code lines are:
$incnumber=0
// HTML begins here
<?php do { ?>
<?php ++$incnumber; ?>
// repeating table start here
<td class="WADAResultsEntry"><form id="form1" method="post" action="">
if(isset($_POST['download.$incnumber'])){
WA_DFP_DownloadFile("WA_DownloadResult1", "imageresponse/", "".$row_WADAorders['file_response'] ."", "[FileName]", 1, $database_users, $users, "orders", "idorder", "".$row_WADAorders['idorder'] ."", "download_counter");
</form
_________________________________________________________________________
and for the example using unique record id, my code is just
if(isset($_POST["'download'.{$row_WADAorders['idorder']}"])){
<input type="submit" name="download<?php echo $row_WADAorders['idorder']; ?>" id="download<?php echo $row_WADAorders['idorder']; ?>"
value="Download" />
//this code is also with the repeating recordset region
There is a simpler way to go about doing this. See my post to this thread:
showpost.php?p=19527&postcount=11
afkrennie381204
works perfectly - thanks a million
Jason - thank you so very much for this. Works perfectly for me. Really grateful for your help this was turning into a headache for me. Have a great day. Ann
