Update
Thread begun 9/08/2009 12:07 pm by Remco209061 | Last modified 9/11/2009 1:12 pm by Jason Byrnes | 2496 views | 3 replies |
Remco209061
Update
Hello,
I want to set a default name for an image in an update form, in the manual I shouldtake theWADAUdateForm option HiddenField but notting happens?? The field stay's empty. also in the 'DefaultFileName'= "" in the script WA_Uploadresult1 Params
Is possible to do this manual?
anonymous
Remco,
I remember there being a slight issue on some machines where once you set the default image dynamically, you have to press the tab or enter key while inside that input field. Try that to see if that fixes your issue... also be sure you have the latest build of DFP2... they released a beta version that will be listed in your account that should fix the problem as the first version of DFP2 had a problem setting the value for default file.
Cheers,
Brian
Remco209061
nono
Hi, I'm using 2.0.1 thats the latest version. The Key combination's dont work. There must be a'n manual solution.
grts
Try using the beta build that is available in the Beta build section of the DFP Download page.
