1 Column Fixed, Rounded Corner Layout
Thread begun 9/07/2009 3:46 am by reg.phipps388482 | Last modified 9/09/2009 9:04 am by Justin Nemeth | 2717 views | 3 replies |
reg.phipps388482
I'd like to create a single column layout with rounded corners is there a layout available to do this?
Justin Nemeth
There is not a built in 1 column rounded corner layout. However, you can create your own. Check out this support doc that explains how to work with rounded corners in CSS Sculptor 2.
csss2_rounded_corners_ht.pdf
-justin
reg.phipps388482
Thanks Justin, that really helped. Do you know where I can get information on using CSS SCULPTOR with SiteAssist Professional. I'd like to use a CSS SCULPTOR layout to generate a site using SiteAssist Professional.
Justin Nemeth
Here is a support doc that talks about creating a custom SiteAssist Pro layout based on a CSS Sculptor preset: siteassistpro_update_sculptor_mw_ht.pdf
FYI, I got both of these docs under the support section on our site. That is the best place to find these how-to docs and other things about the extensions.
-justin
