CSS Sculptor and IE8
Thread begun 3/30/2009 1:57 pm by caricatu310873 | Last modified 6/08/2009 1:49 am by steve361520 | 7725 views | 10 replies |
caricatu310873Beta Tester
Hello Folks,
Are there any issues with CSS Sculptor and IE8?
Regards,
Bill
None reported since the release. We have not finished official QA, but there aren't any we anticipate.
Good to know.
steve361520
Yes, there are.
My site looks perfect in IE 7, but when I upgraded to IE 8 this morning, one of my pages backgournd images does not display and the alignment of text in the top nav, footer, and left and right columns is screwed. Having said that, this is likely an IE issues rather than CSSS. When I click the Compatibility button in IE 8, my site looks cool again. This is a pain if your not a css coder.
Steve
Do you have a sample url where we can view the problem?
RobertB
I have not had any problems with about 12 sites I built with sculptor and IE8.
steve361520
The url is
The site looks fine in IE 7 and IE 8 Compatibilty Mode, but IE 8 normal mode changes the alignment of text in the:
1. top nav div
2. left column div
3. right column div
4. footer div
and removes the right corner background image from the header div.
The only thing I have changed on this page is inserting an include file in each div, the code otherwise is pure CSS Sculptor - which has been my best friend up until now
Steve
steve361520
Ahh...... its the <p> tags in my include pages that are causing the problem!
top.php
<p>Problem Here</p>
If I remove the <p> tags the text is aligned exactly where I want it. But surely the <p> tags are important? Am I missing something basis here?
The missing header image is still an issue, its just disappeared!
Steve
Justin Nemeth
p tags render differently in the various browsers. This can be fixed by zeroing out all the properties of a p tag and explicitly defining how you want it to look. Try this:
p {
margin: 0 0 10px 0; /* assuming you want some bottom space after the p tag */
padding: 0;
steve361520
Thanks Justin, I will try this and comeback.
Steve
