Problems in IE 7
Thread begun 8/30/2009 11:42 pm by bernardmkn361339 | Last modified 9/01/2009 2:22 pm by Jason Byrnes | 3805 views | 5 replies |
bernardmkn361339
Problems in IE 7
Menu works fine on every browse including IE 6.0 & 8.0 but not on IE 7.0 .
Itt basically displays as plain text without the images and no css style . www.washingtonsportsmaketing.com
The print style block contains an opening comment, but no closing comment. Change:
html:
<style type="text/css" media="print">
/* It is common to set printer friendly styles such as a white background with black text. */
body {
background-color: #fff;
background-image: none;
border-color: #000; /* Sets the border color properties for an element using shorthand notation */
color: #000;
</style>
to:
html:
body {
color: #000;
</style>
bernardmkn361339
thanks but that's not it...
on IE 7 it shows that there's an error on line 48 where this is
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }, true); }</script>
Yes, I saw that error as well, it was fixed by adding the closing comment to the the print styles section as suggested in my previous post.
When I visit your site at the address you providede, I see that you have not implmented my suggestion. try changing the print style block:
html:
body {
color: #000;
</style>
to:
html:
body {
color: #000;
</style>
bernardmkn361339
yea u were right. I mistyped the closing comment..thanks
you're welcome.
