map center problem
Thread begun 8/23/2009 9:53 am by jonathan.meilleur385477 | Last modified 8/25/2009 8:29 pm by Dani Chankhour | 3101 views | 3 replies |
map center problem
Hi, I have a problem with the links to change which address your map centers on.
When I click on it, the info bubble and the target is offset (out of the frame) in a corner.
What can I do for it?
Please post a URL where I could see the problem to investigate the cause.
Here it is :
fr_contact.php
Thank you.
Dani Chankhour
In order to fix this issue, you will need to change a few thing:
1. in the wagmp_map_1.js file, please change line 26 to read:
return WAMapPoint(this.markers[x],this.addresses[x],this.icons[x], this.points[x], this.obj);
2. then replace line 13 with this line of code:
function WAMapPoint(theMarker, theAddress, theIcon, point, map) {
3. and finally add this line of code below line 17:
map.setCenter(point, 13);
This should center the map every time you click on the link.
Let me know if you have any other questions.
