Expanding WADA _Products Query
Thread begun 8/22/2009 10:01 pm by Nigel | Last modified 8/27/2009 6:05 pm by Nigel | 4729 views | 4 replies |
Nigel
When I go to the bindings panel and expand the recordset WADAProducts, I get this error:
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2.
So I tried to re-create my local Products table from the one on the server to make sure it was up to date and compatible, but running the create table query gives:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '"products" (
"ProductID" int(12) NOT NULL auto_increment,
"ProductSKU" var' at line 1
SQL for that table:
CREATE TABLE IF NOT EXISTS `products` (
`ProductID` int(12) NOT NULL auto_increment,
`ProductSKU` varchar(50) NOT NULL,
`ProductName` varchar(100) NOT NULL,
`ProductPrice` float NOT NULL,
`ProductWeight` float NOT NULL,
`ProductCartDesc` varchar(250) NOT NULL,
`ProductShortDesc` varchar(1000) NOT NULL,
`ProductLongDesc` text NOT NULL,
`Specs` text,
`Accessories` text,
`ProductThumb` varchar(100) NOT NULL,
`ProductImage` varchar(100) NOT NULL,
`ProductCategoryID` int(11) NOT NULL,
`ProductUpdateDate` timestamp NOT NULL default CURRENT_TIMESTAMP,
`ProductStock` float default NULL,
`ProductLive` tinyint(1) default '0',
`ProductUnlimited` tinyint(1) default '1',
PRIMARY KEY (`ProductID`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=20 ;
I finally got this to work by exporting the table and saving as a file, then importing that query from the file. But still get the 1064 error when trying to expand the recordset.
I'm running WAMP5 (MySQL 5.0.45) locally, 5.0.81 on the server.
On what page are you trying to open the WADAProducts recordset? That recordset occurs on a number of different pages all with slightly different SQL.
Nigel
Hi Jason.
I think it happened on a few pages that have the WADAProducts recordset. It definitely happens on both versions of Products_Detail.php (front end page and Admin page). All the other recordsets on those pages could be expanded.
The query we are using is too complex for the DW recordset to follow. You would have to update it in code view.
We will probably define a query in the mySQL database in the next version of Powerstore so that the recordset query can be simplified and made editable in DW server behaviors.
Nigel
Thanks Ray, that's what I did.
