Email sent to address depending on chosen subject
Thread begun 8/19/2009 8:06 am by MsEvette | Last modified 8/21/2009 7:18 am by Ray Borduin | 3977 views | 5 replies |
MsEvette
Is it possible to have an email sent to a particular email address depending on which subject is chosen? For example, if the "service" subject/option is chosen, the email needs to be sent to the service department's email address. If "sales" is chosen, it needs to be sent to the sales department's email address...and so on. Somebody please tell me how this can be done.
anonymous
Sure, the quickest way is to wrap the Universal Email into an "if" statement and check if the $_POST variable contains a particular value. You could replicated the wrapped if statement with the email however many more times you needed just changing the variable of the send to address within each and of course modify the value of what your if statement is checking.
So in other words it would like this
if ($_POST['selection'] == "value 1") {
UNIVERSAL EMAIL CODE with address 1
} else if ($_POST['selection'] == "value 2") {
UNIVERSAL EMAIL CODE using address 2
} etc. etc.
So, I would create one Universal Email instance and then just copy like above making a change to the send to address.
Cheers,
Brian
That would work, or you could just add the code to the top of the page:
$defaultAddress = "you@yourcompany.com";
$defaultAddress = "sales@yourcompany.com";
and then specify the email address as <?php echo($defaultAddress); ?> in universal email.
anonymous
Ray... yeah, I guess that would be more efficient. I was typing too fast without really thinking about logic! :)
MsEvette
How should it be done if I wanted not only an email sent to a particular email address depending on the subject chosen, but also that same email be sent as a blind courtesy copy to a different email address?
Just use the BCC field instead of the to field when you set it to <?php echo($defaultAddress); ?>. You would need to fill out the TO field as well.
