Form sent to email address depending on option chosen
Thread begun 8/18/2009 3:01 pm by MsEvette | Last modified 4/05/2010 8:59 am by Jason Byrnes | 12359 views | 11 replies |
MsEvette
What's it going to take to set up my contact form with the following option? The recipient of the form needs to match up with the option chosen. For example, if the "service" option is chosen, the form needs to be emailed to the service department's email address. If "sales" is chosen, the form needs to be emailed to the sales department's email address...and so on. Somebody please tell me how this can be done.
Create a select list where the values are the email addresses to send to:
html:
<select name="sendTo">
<option value="sales@domain.com">Sales</option>
<option value="service@domain.com">Service</option>
<option value="support@domain.com">support</option>
</select>
then on the contactus.php page, change line 37:
$RecipientEmail = "".($WAGLOBAL_Contact_Email_To)  ."";include("WA_Universal_Email/WAUE_contact_1.php");
to:
$RecipientEmail = "".(isset($_POST['sendTo'])?$_POST['sendTo']:"")  ."";include("WA_Universal_Email/WAUE_contact_1.php");
MsEvette
One step further...bcc code needed.
Thank you for the option value code...it works great. I'd like to take this one step further and add a bcc to each option. Would you please be so kind and give me that code as well?
create another selec t list:
<select name="ccTo">
</select>
and edit line 30 of the WA_Universal_Email/WAUE_contact_1.php file:
$WA_MailObject = WAUE_AddCC($WA_MailObject,"".($WAGLOBAL_Contact_Email_CC)  ."");
to:
$WA_MailObject = WAUE_AddCC($WA_MailObject,"".(isset($_POST['ccTo'])?$_POST['ccTo']:"")  ."");
MsEvette
Thank you for your reply. Unfortunately, the second code you gave me doesn't do what I'm looking for, unless I just don't know what I'm doing. I want to "add a bcc to each option", not add another drop down menu/list in addition to the list I already have. Basically, if the sales department is sent an email because "sales" was chosen in the form, I want that same form to be blind courtesy copied to the general manager without the sales department knowing it was sent. Can this be done?
Does the email need to be cc'd to the same GM email address regardless of which selection is made?
if not, what are the criteria to determine which address it should be sent to?
If it goes to the same address for each selection, just set the $WAGLOBAL_Contact_Email_BCC option in the WA_Globals.
If it goes to a different address, you will need to create an switch case statement like this:
if(isset($_POST['sendTo']) && $_POST['sendTo'] != "") {
  switch($_POST['sendTo']) {
    case "sales@domain.com":
      $WA_MailObject = WAUE_AddBCC($WA_MailObject,"salesGM@domain.com");
      break;
    case "service@domain.com":
      $WA_MailObject = WAUE_AddBCC($WA_MailObject,"serviceGM@domain.com");
      break;
    case "support@domain.com":
      $WA_MailObject = WAUE_AddBCC($WA_MailObject,"supportGM@domain.com");
      break;
just after the following line in the WA_Universal_Email/WAUE_contact_1.php file:
$WA_MailObject = WAUE_AddBCC($WA_MailObject,"".($WAGLOBAL_Contact_Email_BCC)  ."");
MsEvette
Great, thanks! Right now, each email is receiving a subject line that is coming from the WA_Globals file, and all emails have the same subject line. I need each email address to have its own unique subject line. Is this possible? And if so, would you be so kind as to reply with the proper code for this task?
Same sort of switch case logic. in the WA_Universal_Email/WAUE_contact_1.php file, change:
$MailSubject     = "".($WAGLOBAL_Contact_Email_Subject)  ."";
to:
$MailSubject     = "Default Subject";
      $MailSubject     = "Sales Subject";
      break;
      $MailSubject     = "Service Subject";
      break;
      $MailSubject     = "Support Subject";
      break;
MsEvette
Thank you for your excellent support. I now have my contact form set up exactly the way I need it.
You're welcome.
