Add To Cart Bindings tab
Thread begun 3/26/2009 3:48 am by stuart144478 | Last modified 3/26/2009 3:48 am by stuart144478 | 1660 views | 0 replies |
stuart144478
When I try to enter values in the Default Value fields, I hit the enter key after each new value. Then I select the next Column but the value field still shows my previous Column's default value. I have to click around several times to get the right value ready for editing.
I'm using eCart 4 but this was the same problem with v3. I'm on an iMac running DWCS4 on OS X 10.5.6.
I'm sure it's a bug because I had this under DWCS3 on my G4 Powerbook running OS X 10.4+ as well.
