eCart will not calculate more than 1 (one) shipping rule
Thread begun 3/25/2009 6:21 pm by vwdreamer196703 | Last modified 3/26/2009 2:44 pm by vwdreamer196703 | 3072 views | 2 replies |
vwdreamer196703
I have two rules setup in the eCart object.
However, it only applies the amount of the rule that is listed FIRST (you know how you can change the order of rules).
Both of the rules are active, and if i change the order, each of the rules work.
However, the shipping total is only calculated off the FIRST rule, not the second!!!
I just tried upgrading, and that doesn't change anything. I am on a deadline and this is the very last thing that i need to work out!!!
What do I do?
Please help!
Thanks in advance.
Post a support incident. I'm not familiar with this problem, but we can have an engineer debug it for you to try to determine the issue.
vwdreamer196703
Ray, Thank you for your response, I have since just hard-coded (PHP) the correct calculation.
I will open a ticket, however.
