Universal Email and testing server
Thread begun 3/24/2009 3:54 pm by webmaster359615 | Last modified 6/01/2009 5:58 am by jenkolaka19379118 | 6313 views | 7 replies |
webmaster359615
A lot of tho WebAssist Web Developer Suite extensions suggest a testing server, so I set one up on my local machine using XAMPP. Everything works just great except Universal Email. For some reason, errors like the following pop up on top of the pages (the first is from a Contact Form Solutions Pack page):
Warning: mail() [function.mail]: Failed to connect to mailserver at "yourmailserver.yourdomain.com" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in C:\xampp\htdocs\pd\httpdocs\WA_Universal_Email\Mail_for_Linux_PHP.php on line 257
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\pd\httpdocs\WA_Universal_Email\Mail_for_Linux_PHP.php:257) in C:\xampp\htdocs\pd\httpdocs\contact.php on line 34
AND THIS
Warning: mail() [function.mail]: SMTP server response: 553 We do not relay non-local mail, sorry. in C:\xampp\htdocs\pd\httpdocs\WA_Universal_Email\mail_PHP.php on line 254
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\pd\httpdocs\WA_Universal_Email\mail_PHP.php:254) in C:\xampp\htdocs\pd\httpdocs\orderform.php on line 53
I should note that the mail seems to be working fine when I use the test form provided in the XAMPP interface.
deanmaury365211
local machine email
I'm running xampp as well, but I believe it does'nt include a mail server. There are softwares out there to add mail to your local machine. Some of the errors you mentioned are caused because it is looking for a server that's not there. (Mail) Anytime you put a email on a page, you have to name your SMTP server. (yourmailserver@yourdomain.com) has to be filled in with the proper setting.
Dean
Dean is correct. These would appear to be issues with your smtp email server configuration and not problems with the UE code.
tom92909Beta Tester
Just to throw my 2 cents in...
I typically use the real live server for my development, but I do this all inside a secure testing sub directory. That way I'm assured that I'm getting full access to the true environment for the actual domain.
jenkolaka19379118
Originally Said By: tom92909
I have just used your methos and it worked! My only question is what do you mean by "secure testing sub directory"? How do I make the sub directory secure?
jenkolaka19379118
Hello,
I was trying to us UE on my local testing server but I could not get it to work. Based on the suggestions here I have had to use my remote server and UE works fine here. The problem is I am still developing the whole site but when I use dreaweaver to preview my site pages it uploads onto the server. This means that the public can view my unfinished site.
Is there a way you can test on remote server without people being able to view the site?
Or
Is there a way UE can work on testing server?
anonymous
Originally Said By: deanmaury365211
Dean
In general you can't use a mail server at another server location because it will require authentication. There are a couple of ways around this but the easiest solution is what Tom suggests.
jenkolaka19379118
I have just used Tom's method and managed to get it to work now, thanks.
Just for knowledge sake, how would you configure to get it to work on a local/network testing server.
