problems with drop down falling behind flash in safari
Thread begun 8/12/2009 9:31 pm by gruant2000381341 | Last modified 9/18/2009 9:50 am by Jimmy Wu | 11055 views | 16 replies |
gruant2000381341
I am having issues with my menu drop down falling behind a flash area in Safari.
tom250037Beta Tester
Looking at the source for that page, in the flash parameters I see you have
<param name="wmode" value="opaque" />
If you change that to
<param name="wmode" value="transparent" />
then it should work fine.
Tom
gruant2000381341
I tried that, and it is still falling behind the flash
Actually, I still see wmode set to opaque in the first set object parameters. It looks like that parameter is in there twice. Try removing one, or setting them both to transparent.
I dont have a mac handy, but in Safari for windows, even now, it works fine.
Tom
gruant2000381341
Well I changed the top reference and deleted the second, and I still am getting the fall behind in my safari 4 for windows. I think I'll call around and try to find someone with a mac.
gruant2000381341
I don't know what's going on, now it's falling behind in firefox as well, and I already tested that browser....I think
That is odd!
I am running Safari for windows 4.0 (530.17) and it works fine. Menu is over the top of the flash as it is supposed to be.
And I just fired up my mac, that I use for testing, and it looks good there too.
mac os 10.5.7 Safari 3.23
Although in FF, its not working now. That is likely due to removing the second instance of the wmode parameter. I think that one was there for non ie browsers
gruant2000381341
Well it looks like that 2nd instance was for firefox..I replaced it and firefox works again.
phania389114
re: problems with drop down falling behind flash in safari
Hello All,
I too have the same problem with safari 4 browser. I have the website www.retailtechnologyexperts.com which has a flash on the home page. It does not have any problem with ie7, ie8, firefox or chrome. In all these browsers, the flash behind the navigation bar, but only in the safari 4(530.17) browser..the navigation bar hides behind the flash,,,can any one provide any hints..thank u in advance...
i can also provide with a screen print ,,, if required...
gruant: were you able to get the issue resolved? The page says you are currently updating the site when I try to view the link you sent me.
phania: The dropdown menus look fine when I view the page in Safari. Did you change anything since you made the post?
