Known issue - Pages with Progress Bar wont work.
Thread begun 12/31/2012 9:59 am by Jason Byrnes | Last modified 1/10/2013 1:50 pm by Jason Byrnes | 13609 views | 5 replies |
We have found an issue on pages that have a progress bar and use a Button Submit trigger for any server behaviors. This includes pages created by the Data Assist and security assist wizards. Attached is an updated copy of the webassist/progress_bar/jquery-blockui-formprocessing.js file to correct the problem.
We will release an update in the next week or to with the fix.
Andrew Read
Hi Jason,
Just updating. If I replace this in the following folder it should update on the new sites automatically right?
"userfolder"\AppData\Roaming\Adobe\Dreamweaver CS5.5\en_US\Configuration\Shared\WebAssist\Preview\webassist\progress_bar
Should this one be updated too?
"userfolder"\AppData\Roaming\Adobe\Dreamweaver CS5.5\en_US\Configuration\Shared\WebAssist\DigitalFilePro\Helpers
only the one in the:
"userfolder"\AppData\Roaming\Adobe\Dreamweaver CS5.5\en_US\Configuration\Shared\WebAssist\Digital FilePro\Helpers
folder needs to be replaced.
Jared Lui
Is this what is causing a FORM to be created on Results pages or do I need to create a new Thread?
no, this will have nothing to do with a form being created on the results page.
what kind of form is being created on the results page? a search form?
if that is the case, in the Data Assist Wizard, there is an option to include the search form on the results page, make you sure you deselect that option.
this issue is now corrected in version 1.1.2
