Style not showing up in html editor
Thread begun 11/24/2012 6:29 am by bryan107833 | Last modified 11/26/2012 12:42 pm by bryan107833 | 2973 views | 4 replies |
bryan107833
I have setup two different sites with CMS and when you go to edit the pages the HTML editors do not even show the Style dropdown lists. Any ideas why this is not showing? How to get it to show up? And then finally, once it is there is there an easy way to attach an additional CSS sheet to it? Thank you.
edit the HTML Editor instance on the page, next to the editor preset, click t he pencil icon, then go to the styling tab, you can attach the style sheet on this page, then go to the Modify the Options listed in the styles menu section to specify styles that should be listed.
bryan107833
If you look at the image I sent I think you will see that there is no pencil or presets...I guess I could be missing it but I have looked and looked. Thanks.
the screen shot you sent is of the page in the browser.
I am referring to using Dreamweaver to edit the HTML editor instance.
you need to have Data Bridge in order to edit the HTML editor instance.
open the page in Dreamweaver, select the HTML editor instance in design view, then click the edit button in the property inspector.
bryan107833
Sorry, thank you. I got it!
