simple forms calculator
Thread begun 8/04/2009 9:27 pm by david.barrack304604 | Last modified 8/05/2009 6:33 am by I-CRE8 | 3713 views | 1 replies |
david.barrack304604
Maybe I'm missing it but what's the easy way to display a simple function in a form field based on other form fields? So if A and B were form fields how would I display A*B in another form field, say C? It seems like it would be so obvious but I'm going in circles. I'm guessing I should use a session variable to do the calculation and see the form field, in this case C, to the session variable. But can it be that dynamic? Do I need to use a button to make the session variable and calculation trigger? Thanks and sorry if these are plebeian questions. I've been away DW for a bit.
I-CRE8Beta Tester
If you want a DW extension then Kaosweaver has a free (donation optional) extension that will do this via JavaScript for you demo here : index.php?id=28
