Paypal notice to my client
Thread begun 8/08/2012 11:53 am by Patrice | Last modified 8/08/2012 12:17 pm by Patrice | 13907 views | 4 replies |
PatriceWebAssist
Paypal pro.... Client just received this notice. Please advise how it affects PS 4
In a bulletin dated October 18, 2011, we announced that we were going to expand the number of IP addresses for www.paypal.com to improve our site’s performance, scalability and availability. As part of this transition, we planned to discontinue support for HTTP 1.0 protocol starting February 1, 2013.
We have recently identified that this change may impact the ability of some of our merchants to perform IPN (Instant Payment Notification) post-back validation or PDT (Payment Data Transfer) posts to www.paypal.com. This happens when the IPN or PDT scripts use HTTP 1.0 protocol and do not include the “Host: www.paypal.com” header in the HTTP request.
Additional Details
Starting February 1, 2013, we will require all incoming requests to have a “Host” header which complies with HTTP 1.1 Specifications. This header was not required under HTTP 1.0. IPN and PDT scripts using HTTP 1.0 may start failing with “HTTP/1.0 400 Bad Request” errors after February 1, 2013, which will result in IPN messages not being validated successfully, or PDT scripts not being able to retrieve transaction information.
Action Required before February 1, 2013
Merchants need to update their IPN and/or PDT scripts to use HTTP 1.1, and include the “Host” header in the IPN postback script.
Example:
ASP
//Set values for the request back
req.Method="POST";
req.Host="www.paypal.com";
req.ContentType="application/x-www-form-urlencoded";
Perl
$req=HTTP::Request->new('POST', 'https://www.paypal.com/cgi-bin/webscr'); $req->content_type('application/x-www-form-urlencoded');
$req->header(Host=> 'www.paypal.com');
PHP
// post back to PayPal system to validate
$header .="POST /cgi-bin/webscr HTTP/1.1\r\n";
$header .="Content-Type: application/x-www-form-urlencoded\r\n";
$header .="Host: www.paypal.com\r\n";
Java
HttpsURLConnection uc=(HttpsURLConnection) u.openConnection(); uc.setDoOutput(true);
uc.setRequestProperty("Content-Type","application/x-www-form-urlencoded"); uc.setRequestProperty("Host", "www.paypal.com");
The PayPal Sandbox has been configured to reject any HTTP requests without the “Host” header with HTTP 400 error. Merchants can use the Sandbox environment to certify the changes to their IPN and PDT scripts.
For more information on PDT and IPN, please refer to pdt and ipn. For additional information about this change, please refer to mts.
Sincerely,
PayPal
this wont efect you at all if your are using paypal pro. it will effect you if you are using Paypal Standard.
if you use paypal standard, you will need to update the WA_eCart/WA_eCart_Definition_PHP.php file, and change:
$header = "POST /cgi-bin/webscr HTTP/1.0\r\n";
  $header .= "Content-Type: application/x-www-form-urlencoded\r\n";
to:
$header = "POST /cgi-bin/webscr HTTP/1.1\r\n";
  $header .= "Host: www.paypal.com\r\n";
PatriceWebAssist
Great...thanks Jason.
Any issues with ecart with paypal express?
(Different client/domain that uses ecart)
none that i can tell from this message.
it is only applicable to paypal standard.
PatriceWebAssist
Thanks much, as always...
