Removing <dataset label=""> cuts off Y-Axis label tick
Thread begun 8/04/2009 10:35 am by tom92909 | Last modified 8/05/2009 8:50 am by Jason Byrnes | 5218 views | 4 replies |
tom92909Beta Tester
I'm using Dynamic Web Charts in an dynamic XML configuration.
The chart is working correctly and I am one step away from perfection! I just need to resolve this last display issue.
When the <dataset label=""> is removed, it also chops off the top half of the Y-Axis label tick for the upper range number. How can I avoid this?
For visual reference...
I hope this helps you better understand my problem.
Do not remove the dataset tag, it should be left in place. removing the dataset tag creates invalid XML.
tom92909Beta Tester
I'm not actual removing the entire tag. Only the value inside the quotes.
<dataset label="">
tom92909Beta Tester
Jason,
Your comment about the invalid XML helped me locate my problem.
I had disabled the <title> tag to create a custom header. Doing that
created a gap or void that was actually required by the application for
proper output. Putting the <title> tab back corrected the error.
Thank you!
Originally Said By: tom92909
<dataset label="">
Instead try using the following:
<dataset label="&nbsp;">
