Delete multiple records and files?
Thread began 6/26/2012 5:20 am by MikeH | Last modified 8/16/2013 1:50 pm by Jason Byrnes | 3940 views | 21 replies |
MikeH
Hi
Im am trying to work out how to use DB to solve this:
Two database tables:
TableA:
ID
description
TableB:
ID
Thelink (Same as TableA ID)
Imagename (associated image is on server)
If I want to delete TableA record 50 how would I use DB to delete the record from TableA and ALL assocated records from TableB and finally the image files named in each TableB record there could be various amounts linked to a record in TableA.
Im assuming this is possible using Db just not sure how to start.
Mike
Ian S
This post has been deleted.
the record deletion is the easy part.
your delete page will have a hidden element that is used to pass the ID of the record to delete, in your example, the value of the hidden element would be 50:
<input type="hidden" name="deleteID" id="deleteID" value="50" />
you would add two delete record behaviors.
the first for tableA, set the key column to ID and the value to use the deleteID hidden form element.
in the second delete behavior for tableB, set the key column to Thelink and for the value use the deleteID hidden element again.
the tougher part will be deleting the files. This will take a little bit of hand coding, but not to much.
First create a recordset to query tableB and filter the Thelink column using the deleteID form element.
This will return a recordset that contains all of the file names to delete.
Then add the delete file behavior, set the trigger to recordset recordsetName is not empty
Set the Delete folder to the folder that contains the images to delete.
for the file name, click the lightning bolt icon and select the Imagename column
the delete file code on the page will look similar to this:
$WA_DeleteFileResult1
false;
if((
$totalRows_recordsetName == 0)){
$WA_DeleteFileResult1 WA_FileAssist_DeleteFile("imageFolder/""".$row_recordsetName['Imagename']  ."");
We need to add a loop around that code to loop through the recordset:
<?php do { ?>
false;
if((
} while ($row_recordsetName mysql_fetch_assoc($recordsetName)); ?>
MikeH
Thanks Jason
How would I get the file delation to start only when the form "delete" button is pressed?
Mike
My solution already tries to delete only if the form is posted.
since the file delation relies on the recordset not being empty, and the record is filtered on the form variable.
The only way the recordset is not empty is if the delete button is pressed.
MikeH
hi Jason
Thanks I couldnt get it to work. It did not appear to do anything.
If you are ever bored the files attached.
You are busy enough so do not worry.
Mike
pgn_delete_car.zip
everything looks correct.
I suspect that if you where to refresh the page, it would show that the record where deleted.
There isn't a redirect to another page, that is why it appears not to do anything.
on the server behaviors panel, click the plus button and select WebAssist -> Utilities -> Server redirect.
Set the trigger to Current page Submit and select the results page.
MikeH
Hi Jason
I added that and it does redirect but even though I have told it to redirect to the correct page it gives a 403 forbidden and has tried to go where I never told it to :)
Also no deletions took place neither records or files.
A little annoying considering you have taken the time out to help. Does certainly feel like its wasting your time. Possible time for a multiple file delete beahviour from WA :)
Mike
send a current copy of the page please, the redirect is probably happening before the delete.
MikeH
Thanks Jason
Its attached... for some reason its trying to go to a plugins directory but that wasnt where the resirect is set to.
Mike
pgn_delete_car.zip
