Products pods not lining up
Thread began 6/13/2012 3:14 am by lr_leal239405 | Last modified 6/13/2012 11:17 pm by lr_leal239405 | 226 views | 6 replies |
lr_leal239405
The fourth box is bumping up against the third and on the second row the second box is doing the same. They should line up perfectly. How to fix?
Also, why doesn't it show the 10th product. The second row only shows 4 instead of 5 products.
I'd like to change the limitation to show at least 5 rows (30 products). Which file can I alter this in?
thank you.
please post a link where i can see the problem.
lr_leal239405
I meant to post the link but forgot. Here it is:
products_results.php
thank you.
the grid results page is designed to show a total of nine records in the 3 columns.
to change this, so it will show 30 in 5 columns,
edit the webassist/plugins/catalog/results_grid.php file.
change the following line:
$maxRows_WADAProducts = 9;
to:
$maxRows_WADAProducts = 30;
and change this line:
<div class="contentBoxGrid  ps_main borderColor<?php echo(($prodCount%== 0)?" thirdBox":""); ?>">
to:
lr_leal239405
Thanks. Most everything is working as it should now, except the main category has a bullet as well. Where's the script to remove that one only?
products_results.php?Search=0
Remove the background image from configurable.css (line 268):
dl.nestedaccordion dt
and add it to configurable.css (line 296):
dl.nestedaccordion dd dl dt
lr_leal239405
It worked somewhat different than that but was able to resolve with your suggestion.
I changed dl.nestedaccordion dt image in the configurable.css to none and added the background image to dl.nestedaccordion dd dl dt on the crazy_styles.css file. That did it. Thanks Ray.
